New Member
BMW 318i boot locked can’t get into
And, of course, if you can't open the hood, you can't use the + and - to put power to the doors, windows, lights, keyway, etc.- bmw
- bmw 3 series
(and 4 more)
Tagged with:
21
I just now remembered that you could use under the hood cables to hook up to a good battery. That should allow you to open the boot and doors.- bmw
- bmw 3 series
(and 4 more)
Tagged with:
21
I probably won't be able to remember exactly step by step. (That happened with a 2003 Mercedes, one problem similar to the '92 BMW 325i. That time my battery looked like nearly new, but it was quite old. A new battery solved that problem.) As for the '92 , the instrument cluster lights likely went out some day before that day. It works, but lights are out. I have some extra lights; just haven't removed it yet. I have a few clusters that I have bought used over the years. Now the most important: The back driver's side door window was opened about one inch; I used a coat hanger to pull knob up; (the driver's door). After that it was easy. I put a new battery in and turned the ignition key; all was good. You might have to use a circular hole saw behind your car tag to open the boot.- bmw
- bmw 3 series
(and 4 more)
Tagged with:
Rear View mirror has come off windscreen screen
Never experienced this before but the rear view mirror has seemingly parted company from the windscreen. It seems that a round metal disk should be glued in some way to the windscreen and then the plastic housing can be put back. Any experience/instruction out there on how best to go about reattaching this? -
21
Hi did you solve problem that your boot locked and no power ?? Also me got same problem 318i 2011 unfortunately i disconnected battery and closed the boot . Is there any easy solution ??- bmw
- bmw 3 series
(and 4 more)
Tagged with:
