Read all discussions on swirl flaps and decided best bet was to remove them after removing manifold it looks like I have a newer version as the rod is internal and if I remove it there will be holes between the ports the shaft has a lot of play at the end .I found one of the clips had come off and was just floating on shaft I refixed it and there's still play is it a new manifold?
      Alloy wheels
