Hi. So I have had my 335i 2008 since June. Its only done 35k. Had nothing but troubles since I got it which is frustrating to say the least.
So yesterday I was driving it and noticed it was stuttering and then the engine management light came on and I was basically in limp mode. I pulled over, turned it off, restarted, light went out but as soon as I accelerated it stuttered and light came back on.
Its booked into dealership tomorrow. My question is what do you think it could be. I am thinking:
Vanos, HPFP, injectors, coil pack?
Any other suggestions would be most welcome. I prefer to go in with a bit of knowledge as its still under warranty and I don't want to get fobbed off.
Thanks
Cant really help without knowing the fault codes. It may be worth you getting one of these so you can check for yourself what is wrong before taking it to the stealer.
http://www.ebay.co.uk/sch/items/?_nkw=c110&_sacat=&_ex_kw=&_mPrRngCbx=1&_udlo=&_udhi=&_sop=&_fpos=&_fspt=1&_sadis=&LH_CAds=&clk_rvr_id=894942675904&satitle=c110&rmvSB=true
It not only gives the code but provides a description. Also you can use it to clear the codes.
      Newbie here
      Appears no fire
      Appears no fire
    5. 12
    • Drumj earned a badge
    • Larry36 earned a badge
    • Graham J earned a badge
    • Sogra earned a badge
