Hi guys,
I have a E90 3 Series
I have had an engine light on for about a week now and I took it to my local garage today. They plugged it in and it came back with a VANOS fault. The car is slightly down on power but otherwise running fine.
They cleared the fault but when driving home from the garage it came back...
I was wondering whether anyone else has had this issue and if so, how much did it cost to put right?
Thanks!
I had the same in my E90 330i - had the engine light reset and within a day or so came back on. Symptoms other than the engine light were some hesitations and slightly lumpy idle every now and then.
I ended up pulling out he vanos solenoids and giving them a clean and swapping them when I put them back in - the fault code came back on but swapped from the exhaust to the inlet - therefore bought a new solenoid from BMW for £86 and changed the inlet solenoid for the new one and it seems to have worked so far.
Very easy DIY (search online for some) and I would suggest getting a BMW code reader (about £35 off ebay) so you can reset or read fault codes.
I believe that BMW have changed the solenoid design as off 2007 so you may find a new solenoid is an improved part?
Also note mines the straight six engine so you may find your parts are a little cheaper?
Alex
I had the same in my E90 330i - had the engine light reset and within a day or so came back on. Symptoms other than the engine light were some hesitations and slightly lumpy idle every now and then. I ended up pulling out he vanos solenoids and giving them a clean and swapping them when I put them back in - the fault code came back on but swapped from the exhaust to the inlet - therefore bought a new solenoid from BMW for £86 and changed the inlet solenoid for the new one and it seems to have worked so far. Very easy DIY (search online for some) and I would suggest getting a BMW code reader (about £35 off ebay) so you can reset or read fault codes. I believe that BMW have changed the solenoid design as off 2007 so you may find a new solenoid is an improved part? Also note mines the straight six engine so you may find your parts are a little cheaper? Good Luck Alex g.png
Agreed with you
      Would you buy this car?
      Selling a BMW wall charger
      BMW electric forum
      BMW electric forum
    • Tony J01 earned a badge
    • Amk earned a badge
    • Glyn6653 earned a badge
    • John perr earned a badge
