The parking brake light / front indicator bulb/ side light.
The indicator works but the parking light doesn't. Have checked bulb and connection. Is there a fuse if so where is it located please. Main fuse bos only shows one fuse for lghting
The indicator works but the parking light doesn't. Have checked bulb and connection. Is there a fuse if so where is it located please. Main fuse bos only shows one fuse for lghting g.png
how much is it???
Rear light housing on the X5 is a known problem they suffer with corrosion problems I would take out the lamp unit and make sure all is clean and dry. It may take a bit of fine emery cloth to clean it all up then retry (don't bolt it all in place) if its working take out the lamps and protect the surfaces with a smear of vaseline then put it all back together.
i had a problem with the o/s rear fog light on my E70 X5,over time the previous owner had been slamming the tail gate shut and the fog light housing where the metal was held on by a plastic pip had worn down.I fixed it with a soldering iron,using heat to spread the plastic pip to hold the metal in place
i dont know if this is any help but maybe it might be worth looking at
      Running Boards
      Running Boards
      650i VANOS failure
    • Wacko Jacko earned a badge
    • GermB earned a badge
    • tomy987 earned a badge
    • Brummieboy77 earned a badge
    • Julian Pasiut went up a rank
