Hi All
I hope somebody can help.
I was cleaning up errors with on my car with PA soft, because I had replaced a abs sensor.
I
also found an error on the ews, so I went into the ews option, coding
and then into settings and manufacturer data, and now beguines the
stupidity :angry: , and don't ask me why but on the DME/DDE Interface I changed
ews 2 to ews 3, thinking if anything whet wrong I could change it back, I
found out that you can’t change it back.
Well now the car won’t
start and I can’t change it back to ews 2 because the option is in light
grey and want let me press on it.
So I went in to the ews with
NCSEXPER, I found that the ews had "EWS_3_SCHNITTSTELLE" is set to
"aktiv", but should be set to "nicht_aktiv"
I tried changing it but I get the following error
Could anyone help me out??? :D
post-12234-0-70960500-1444430409_thumb.j
