Hi Stu, sorry I missed you reply, thanks for that.
Seems I have an odd problem. The key reader can't read the existing key. Even though it works fine.
Nevertheless, I got a copy made and sure enough, it doesn't work!
Is it possible to disable the immobiliser?
Hi Dave, I thought you would dive into that one. I have found a reference to it in the book and it would appear its connected via the computer on the I drive but so far I have not been able to give it the kiss off life. i can follow the instructions so far and then nothing. I will keep trying and if your interested the first reference is on page 85 of my handbook . thanks Paneuro.
Good morning all,
So, having had my car for a little over 6 months I decided to give the transmission an overdue service.
Parts obtained from Autodoc for £205 for ZF service kit, a fill plug & mechatronic sleeve (Just in case)
Job wasn't that bad to do. I even found the source of an intermittant rattle from un undershield.
Once done I cleared the adaptions & drove up the road, instantly the shifts were noticeably smoother, not that they were too bad before, just slightly less refined.
ZF recommend it to be done at 60K I believe, my car has covered 79K miles. I might do just a fluid flush at 100K miles, we'll see...
