Folks, I am having starting problems with my 320D E90. The immobiliser doesn't respond to keyfob at all sometimes. The only response I get is an alarm/tone coming from rear wheel arch area. I can manually enter the car however inserting the fob in car doesn't do anything either. It appears that everything is dead which at the time makes me think that its the battery. however half an hour to 4 hours later, car starts with no problem. The battery is original from new and its coming up to 6 years.
This seems to happen on morning after cold nights or rainy days in milder weather. Can someone please tell me where the problem may lie and what would be a good starting point in order to investigate and eventually rectify this issue.
Thanks guys for the advice. I took to a german car specialist garage to understand the likely problem with it. Upon explaining the failure mode he immediate pointed me to a loose 'Battery to Fusebox connection' which is in the passenger footwell of my BMW. I weren't sure about this so he opened the foot well panel, the red live wire from Battery (in the boot) was connected to the fuse box, he shook the wire with little force and the door open light in the interior started to flicker. Now I am kind of sure that that may have bene the problem but I will have to wait and see whether the said fault reappears. The guy was adamant that it is a common problems that the connection works itself loose.
I will still though start saving up for a new battery. Any idea how much a genuine BMW replacement will set me back?
  • 1 year later...
Just seen this post. I believe that my 320i was subject to a manufacturer recall because of this issue.
Expand
yes, seems only the petrol version was recalled. Mine is a diesel.
  On 1/30/2018 at 11:48 AM, Trevor said:
Seems like it is a common problem which can affect other models also...how it comes loose in the first place is another question
Expand
he said that rust causes it, but it was enclosed in the passenger footwell so not sure : | but it has not happened since so the loose connection must have been the immediate cause .
Expand
Hi, 6 years is a good age for a battery, its bound to be feeling its age. If you have a battery charger, couple it up and see if it shows a high charging rate just after the problem occurs, and this indicates your battery is low or flat. Otherwise have your battery tested by a reliable Garage. I had the same trouble during a very cold spell recently, I charged the battery and have had no trouble since but my battery was on the car when I bought it so I dont know how old it is.
      Bmw 116d 2011 her fault codes
    2. 4
      Misfire at 2000rpm
      Misfire at 2000rpm
      Noise
    • welshchy earned a badge
    • Michal earned a badge
    • JohnLC earned a badge
    • rjrive earned a badge
