My BMW 320D Automatic is juddering when holding the car on the brake when in drive. Do I need to replace the clutch or is the problem something else?
Hi Jane...welcome to the Forum!
It sounds like an idle fault if the revs have dropped down to a level where the transmission is juddering.
If this is the case, then maybe try some cleaning additive for the engine (Halfords sell many different types) and a good run may cure it.
If not, then a trip to a local BMW specialist for them to scan the engine control system to diagnose the fault.
I would try the cleaner first though
Regards.   Trevor  - Admin
Thanks, I'll try that...
Much cheaper than a new clutch anyway!
    2. 9
    5. 9
    • Aaronelvis earned a badge
    • Bubba jay earned a badge
