New to the forums so hoping to get a little help here!
First: 2006 BMW 330I, Auto, Stock.
Issue: SO... The car has multiple error lights on the dash, check engine light, ABS light, Traction light... Car is VERY hard to start and will smoke black like crazy. Assuming this is caused by the temp sender issue. Will run but wants to die. Also Idrive has no display and blower dose not.. well blow.
The Pcodes I'm getting are!
P0118- Engine Coolant Temperature Sensor 1 Circuit High
P0158- O2 Sensor Circuit High Voltage (Bank 2 Sensor 2) (assumed caused by above)
P0123- Throttle/Pedal Position Sensor/Switch 'A' Circuit High
Here is what has been done.
DME has been swapped with another DME Set... Same issues
Temp Senders Replaced
New Throttle Valve (OEM)
Negative battery cable with IBS ( Awaiting Arival)
NEW Battery (Programmed)
I have pulled the pins from the DME going to the temp sender, tested perfect continuity with no shorts. We have swapped parts and have done just about everything we can think of.
COULD this be the battery cable that has failed??? Or?? At a complete loss and about to take to the dealer... Please someone have any ideas... ANY???
Purchased the car like this so I don't have a history.
PLEASE & THANK YOU!
I will literally paypal, or mail $100 CASH to anyone's idea that leads to the fix!
Full CODE LIST!
Fault List (DME)
2CF9- DME: Throttle-valve poteniometer 1
CDA1- Message Error (Steering wheel angle, 0cC4), DME receiver, DSC/SZL transmitter
CD98- Message (torque request, DSC, 0xB6) faulty, receiver DME , transmitter DSC
CDA5- Message (status, DSC, 0x19E) faultily, receiver DME, transmitter DSC
CD95- Message (operation, cruise control/ACC, 0x194) faulty, receiver DME, transmitter DSC/SZL/LWS/ACC
Fault List (EGS 6HP Transmission Control)
CF1E- No message from DSC, receiver DKG/EGS, transmitter DSC/KOMBI
CF1A- No message from DSC, receiver DKG/EGS, transmitter CAS/DSC
CF19- No message from DSC, receiver DKG/EGS, transmitter KOMBI/LDM/DSC
Fault List (LDM Longitudinal Dynamics Management)
D016- Message error (operation cruise control/ACC, 0X194), receiver LDM, transmitter ACC
D030- Message (status of KOMBI, 0x1B4) faulty, receiver LDM. transmitter KOMBI
Fault List (IHKA Integrated automatic heating/air conditioning)
E71C- Message (speed, 0x1A0) faulty, receiver IHKA, transmitter DSC
Fault List (JBE Junction-box electronics)
A731- JBE- Supply, terminal 30g-f
A6CF- JBE- AUC sensor
9C5E- JBE- Refrigerant pressure sensor
Fault List (INSTR Instrument Cluster)
A554- Instrument cluster: No message (telephone)
A3B9- Sporadic fault (failure, DSC message, 0x19E) No repair measures available, receiver KOMBI, transmitter DSC
A550- Message (speed, 0x1A0) faulty, receiver KOMBI, transmitter DSC receiver KOMBI, transmitter DSC
A3AC- Message (distance traveled, 0x1A6) faulty, receiver KOMBI, transmitter DSC
Fault List (MRS Multiple Restraint systems)
93FB- No message (vehicle speed) from DSC, ACSM receiver/ MRS5, DSC transmitter
93B2- MRS: Safety battery terminal
Fault List (CAN Communication analysis)
CD9C- DME- Message (speed, 1A0)
FFFF- CANSYS: Communication Fault
  • 5 months later...
FFFF  CANSYS Communications Fault
Looks like the majority of the modules are NOT successfully communicating with each other over BMW's version of the CANBUS obdII communication protocol..  Every message they send.
From the way the messages are worded, it looks like the brains behind the DSC module is the sender (transmitter) of most of these requests that end up as errors; I'm thinking it's querying a whole bunch of different modules in the car for info, but what comes back to it is garbled who knows what or nothing at all because there is physical damage to the CASNBUS (CANSYS) communications wiring somewhere, and as it is a bus-based system, if you sever part of the backbone, anything past that point is "offline" as far as the rest of the car knows --it simply isn't there, communications-wise..Additionally you then have an electrical "termination" issue because the bus must be terminated properly or you can get signal reflections and all kinds of interference.
My thought is that if you find and fix the CANBUS issue, alot of the other errors will vanish, even though they are not canbus specific.  YOu know the DSC is broadcasting load and clear.
You'll need a physical layout of the CANBUS wiring to be able to see what connects where and then figure out from analyzing the messages "if x can send and y can receive then x is good....y....dunno --- it is saying the message is an error".  So Y might be on the damaged part of the bus. Once you get the schematic for the CANSYS it should become more obvious where the damage is.
Derf
