2006 330I, Dash Christmas Tree, 35+ Codes, $100 CASH for the "fix"! PLEASE HELP!
Well got the 240 back yesterday, have to say excellent service from the main dealer repair centre. New wheel looks great, top pic. Wish I could afford the other 3! Going to see who can match the other ones properly. A front one pictured, not that bad I suppose. Alignment all checked etc. Glad it's back- 1
Newbie here
