1987 325 E30 M-Tech 1 Valuation
Misfire at 2000rpm
Hello, my 20 year old 3 series estate (E91) has 93,000 miles on the clock. There are no codes detected at a BMW specialist's garage but there is a slight but noticeable stutter on acceleration. It happens when the engine reaches 2000 rpm in all gears. The vanos solenoids have been replaced, a new fuel pump fitted, new ignition coils and spark plugs. All the injectors have been cleaned and tested. A smoke test for leaks has been done-none discovered. Can anyone think of any other checks that can be done without breaking the bank? -
X5 wanted
I have a 2003 for sale. email me if you like to chat. thank you John. -
Battery Restraint Malfunction / Battery change
Hi Ali Have you checked that the battery holding clamp is in place ? When the battery was changed was swapped like for like? Dave -
Hi Guys, I’m after a bit of advice here! I have changed the battery and now all of a sudden i’m getting the “Battery Restraint Malfunction” warning on the dashboard. When I go to clear the code and restart the engine the warning comes straight back on. Any ideas what to check first? Thanks in Advance. Ali -
7
