Hi all,
need a bit of help here, my 06 2.0d M Sport won't reach normal temperature and it appears it's missing a "flap control" that sits in front of the radiator and electronically controls airflow through the rad. My problem is that there is no contact housing within the wiring harness to accomodate the part. BMW confirm the flap control is listed on the car but I'm still unconvinced. If anyone out there has similar car I'd appreciate it if you could take a look at the front of your rad and see if your's has it. The part number is 51743415851 if you want to view on OEM.Com. It's quite a large plastic duct. Thanks is advance.
    2. 4
    4. 0
