My window won't go down whe you open the door and it won't go down in auto but it goes up and down if the button is keeped pressed. Any ideas?
Hi...welcome to the Forum
You could try a battery reboot/reset procedure to see if that solves the issue.
It could also be a faulty door switch if it's not recognising the door closed it may not drop the window or go into auto-down
Let us know what you find
Cheers  Trevor
    2. 6
    3. 14
    4. 13
      SLIPPING CLUTCH
    5. 13
      SLIPPING CLUTCH
    • Karlos70 earned a badge
    • DDONNY earned a badge
    • Dimitris earned a badge
      Collaborator
    • DAW90 earned a badge
    • jn1253 earned a badge
