hi i have a 2001 x5 3.0 petrol with a fault on the air bag light it comes on and when you drive around corners it goes out and come on again i have looked under the seats but can not see any plugs undone. can any one help me with this please
Sounds like something loose or a rubbed wire earthing, just a thought if someone has been inside the door to work on the door locking mechanism they may have disturbed the air bag connector or not put back something correctly.
Take care inside the door and make sure the membrane is put back correctly as its a known source of wet carpets.
hi i have changed the rear door window unit but the light. any one know of a good obd2 tool that will read air bag faults and reset
thanks for the help
    • DAllen earned a badge
    • Peter 255 earned a badge
