Hi John
What diagnotics are you using ?
Check the main connectors to the cluster for a short to earth as you have 2 blown clusters worth sending one to someone like ECU Testing to see if it can be repaired ?
The cluster recieves information from several modules so a full Diagnostic check may well show the culprit up
840 d 2018
My cluster had blown after and resulting in a battery drain. Managed to source a second hand one which was fitted and lasted 30 mins. Once blown battery drained again and an intermittent 3 second beep in the car when driving. Removed the fuse for the cluster to stop the beeping and the battery stopped draining . Concluding the blown cluster is causing the battery drain but cannot find the cause of cluster blowing.
