I've recent bought my first X5, a 2002 3.0i.
Despite it being looked after previously, the oil currently is rather black and a bit sludgey so i am going to drain and change it.  I've gone for 0w-30 castrol edge, which i'll add a Slick 50 or Wynns Oil boost to.
There shouldn't be any major issues with that right, i know 5w-40 is the default?  The car has just crept over 148k miles.
-Matt
Morning Matt
Welcome to the forum I hope you enjoy your X5
There are many debates on oils but as long as it meets BMW LL ACEA A3 spec it should be fine. If I recall in the hand book it gives a pretty wide range of oils to cover all geographic locations.
I use 5W 30 fully synthetic I have read that additives can cause lazy lifters but have no personal experience, I may go to 5W 40 fully synthetic now mileage is over 100k
Hi Matt....welcome to the Forum
I totally agree with Greydog on his judgement with the oil specs and the fact that your X5 has done a higher mileage I don't think I would go with the lighter grade...best to go with the 5w40 and you shouldn't need any additional additives if you get a quality oil (Mobil1, Shell, etc)
Let us know how you get on with it all.  Cheers,  Trevor
    2. 6
    3. 14
    4. 13
      SLIPPING CLUTCH
    5. 13
      SLIPPING CLUTCH
    • Karlos70 earned a badge
    • DDONNY earned a badge
    • Dimitris earned a badge
      Collaborator
    • DAW90 earned a badge
    • jn1253 earned a badge
