You say you suspect the Vanos is not working but don't tell us what symptoms? What engine? Vanos can fail but generally are pretty tough, if they do fail it is normally either the Vanos solenoid or the seals. If you are a competent DIY mechanic there are seal kits available even full rebuilt Vanos units and how too's on You Tube. If not then you will need a specialist to help google will be your best mate there. Try Mr Vanos they may give more advice
Hi Samuel....welcome to the Club
As Greydog has mentioned, Vanos are pretty reliable and the only time they really play up is if the oil quality is not good and then after a good engine flush the performance can usually be restored.
Let us know what you find with it
Cheers,  Trevor
    • Dipul earned a badge
    • PAUL HN earned a badge
    • BmwSpec earned a badge
    • Fretfulmass earned a badge
    • Sambo_gti earned a badge
