Hi guys n gals, I am currently having a problem with the cold weather affecting the car's door locks ( 3.0 sd) when the temp drops the doors freeze the handles become stiff but will open, once open they won't close they just bounce off the door catch and won't close securely until the car heats up. Plenty of power in battery as car starts every time with no problems. Has anyone had these problems? ? Thanks in advance guys👍
A not uncommon problem condensation inside the door causes the actual lock mechanism to seize up. Take off the door card an carefully peel back the moisture barrier you should be able to see the wire operating rod going down to the door side where the lock mechanism is located I sprayed mine with good old WD40 then worked iy until free then spray grease and its been OK for the last couple of years.
A word of caution if someone has been there before and the moisture barrier is damaged or torn make sure you repair it with tape any splits can allow water into the car (wet carpets)
Thanks very much Dave I'll give bit a try.
Thanks very much Dave thought it was gonna be worse than that I'll give it a try. Cheers mate👍
Morning Mark
Looking at the news and weather today if your OOOP North you have a good oportunity to test the fix !!!
14 hours ago, Greydog said:
Morning Mark
Hi Dave, the weather up here in sunny scotland is a wee bit cold😉 no change there😀 we've got about 5" of snow and the car has behaved perfectly  it's great to just jump in and know the 4 wheel drive will get you anywhere. I had an insignia before this and can't believe the difference.  Thanks again Dave for your help m8
12 hours ago, Trevor said:
Certainly cold enough this morning...we actually had a smattering of snow this morning....first time in 5 years that sunny Bournemouth has had snow.
Hi Trevor, your a lucky man we're up to 5" at the moment and expecting another heavy fall tonight, thank God for heated seats😉.
Still far too cold where I am, I've had to get some graphite key spray to stop mine freezing over!
Mikeyp @ TMS Motorsport
Email us : [email protected]
WhatsApp us for fast response : +447979127236
TMS Motorsport – FERODO PADS – BUY ONLINE
-   We ship worldwide to your door  -
 -  Currently Breaking for parts – Hawkeye Subaru Impreza  - Honda S2000 -
    5. 2
