Posted (edited)
I have got a 2010 BMW X5 and it’s not got sat nav can I just buy one off eBay and fit it
Edited by Darrell newman
I diden5 explain it right
Hi Darrell
Welcome to the Forum , I would check on www.realoem.com to make sure you get a compatible part number for the nav unit and your model you may also need the loom. The nav needs coding to make it work I believe the codes can be downloaded. Not sure if the unit will need coding to the chassis or not but this can be done with INPA and DIS.
Good luck
    5. 2
