Hi
this is my first post
just bought a 2005 645 convertible
everything was working fine except the air con the local garage traced the fault to a sensor and aux water pump, these were changed now my roof does work.
the switches on the dash don't light up anymore, I have checked the fuses
any ideas would be greatly appreciated
tony
Hi Tony....welcome to the Club
If all of the lights are not working then it does suggest a power feed to them is not there, so your diagnosis of a fuse could be correct or alternatively it may be possible that the rheostat to alter the dimming could be at fault
Good to have you onboard
Cheers,   Trevor
      Alloy wheels
    • SteveC51 earned a badge
    • Dan_C earned a badge
