Morning Jordan
Updating your TV tuner is plug n play. The first  method is a search on that well known auction site should get some results but an original Digital tuner will be in the £200+ bracket. Advantage is it will all be controlled from the OEM head unit.
The second method is by a Digital TV Tuner (set top box type) and Audio TV SOT lead, with this method its a bit more work to fit as you will have run some cables as you will need to use a remote to tune the TV channels but they work really well.
I would look at www.realoem.com search your model and you will find the part number for the digital tv tuner these were common across a lot of BMW models with ibus.
As I say not difficult just fiddly
    3. 2
      filter change recomendations
    • Mama1809 earned a badge
    • Alan520d earned a badge
    • First Bima earned a badge
    • Rob Lee earned a badge
