HI,
I have a newer shape 2015 1 series 116D M Sport Auto and want to fit the M1 type of matt silver trims for the driving lamps. The advice says they will only fit a genuine M1 type but I want to know if they can be persuaded to fit as the grills look the same as mine?. Your feedback is welcomed. Thank you
Come on Rod
Do you really think BMW would make it that easy?? Then again why not??
Have you looked at www.realoem.com put the last 7 digits of your Vin in the search box and it will bring up your model, if you haven't used the site before it is a BMW part list which will show all part numbers available for your car. Once you have part numbers you can look at www.newtis.com you can see the BMW workshop instructions and see how it fits together and whether or not the parts are interchangeable.
Hope this helps
    5. 2
