Hello,
Just bought my first Bimmer and it happens to be an X3 and hopefully not a baptism of fire...!!
2009 X3 SE, pretty straight and certainly the best one I've of the four I've driven.
Anything I should be on the look out for?
Cheers
Richearl71
Morning Richard
Welcome to the Forum, congratulations on your purchase.
Service history as always is paramount same with any car, also check with BMW for any recalls/updates that have been due and were they carried out.
If your X3 has a staggered wheel set up (wider rear tyres) take care when replacing tyres make sure all 4 are from a good manufacturer differences in rolling circumference can cause transmission wind up and damage to the transfer box. This applies to all X drive cars and BMW recommend * rated tyres. If the wheels are same size on each corner it is more forgiving but you should still check that all tyres are from a recognized manufacturer and the correct size at least then you have a chance the rolling radius is within tolerance. Apart from that they are good cars ENJOY
If the worst happens there is loads of support here
Cheers Dave, Test drove a couple that seemed to be suffering from wind up, possibly due to mismatched tyres.
Mine so far seems to be performing well, I say that quietly, just in case....!!
Richard
