First aid kit cover
My manufacturer supplied first aid kit lives in a box under the passenger seat, but the cover keeps coming open. On inspection there seems no form of catch for this - is this correct or am I missing a catch or spring to keep it closed?
Martin
Hi Martin
I cannot say whether there should be some sort of seal on there but I would think so...quite possibly, someone has removed it as it would be date stamped (usually 1 to 2 years for the contents to remain steralised).
I would suggest that the contents are okay to use but if you are really concerned then maybe purchasing a new / sealed one is the way forward.
Cheers,  Trevor
Hi Trevor
Sorry, I was probably confusing everyone here by not explaining myself properly - the first aid kit is fine and still sealed. It was the black plastic flap I was referring to on the front of the compartment where the kit is stowed. However, I have since got right down to have a look at it and I just wasn't pushing the clip down far enough to engage with the sprig on the compartment. All is well now thanks and it doesn't keep flying open now.
Thanks
Martin
