Hi,
What's the sketch with the GPS unit in the X5... it's in the boot on the left, where the CD multi changer is.
Does it need a disc?
Subscription?
Morning Gav
What sketch, where?
Two types of Nav system were fitted Business and Professional, if you have a screen up front it will be Professional. Both systems came as CD or DVD, at 2003 your car is on the change over, the Navigation computer in the left cubby needs either a CD or DVD (not interchangable) if your Nav computer has DVD on the front then you need the Professional High DVD. If the computer does not have DVD on the front then you will need the corresponding CD maps.
Do you have a Nav computer? Are the lights on on the Nav computer? Can you eject the disc to see what it is
    5. 2
