Hi. I have plugged in my scanner and when I go into the steering angle sensor information I am getting no change in the degree of steering angle when I'm turning the wheel. I was getting a reading of 727 degrees and no rotation rate.
I cleared the steering angle sensor fault code and calibrated the steering angle sensor and the DSC light goes off. If I turn the car off and leave it for 5 mins the light is back on when I start the car. Can anyone clarify it it's a faulty steering angle sensor
Thanks
Morning John
The Steering Angle sensor is one of the few issues I have not had to deal with, I take it you have cleaned all the connectors/plugs with contact cleaner just in case it is a gungy joint that has a continuity failure when the system self tests at ignition on? Check www.newtis.info for BMW's test and check information.
I have read about a few folks that have had to change the sensor and there are how too's on You Tube and the Pelikan parts website (US site but good info)
2 minutes ago, Greydog said:
Morning John
hi Dave,
thanks for the advise. i will check connections. it seems strange that i am getting no voltage reading or rotation rate. i presumed as soon as i moved the wheel i should see some changes to angle, rotation rate or voltage.
john
Hi john
www.newtis.info is a BMW technical information site as used by BMW Dealers so that should give all the information your looking for regarding tests and expected results
    2. 13
    3. 13
    4. 7
    • Karlos70 earned a badge
    • DDONNY earned a badge
    • Dimitris earned a badge
      Collaborator
    • DAW90 earned a badge
    • jn1253 earned a badge
