Hi all, I have a 2006 X3 and for some reason when the lights are on automatic they stay on all the time. Now I’m not sure if it’s connected but the intermittent wipers only start working after about 20 minutes of driving. My thoughts are that they could both be something to do with sensors relating to the windscreen? Please help?
Morning Ian
The "automatic on" sensors for wipers and lights are in a housing behind the rear view mirror if the screen has been changed they could have come adrift. They stick to the windscreen and measure ambient light and refraction, if they have slipped then it could be why it thinks it's dark all the time. Un-clip the cover and make sure they are stuck to the windscreen correctly.you can buy new mounting pads.
Thanks Dave. I have to say that all I can see behind the rear view morrow when I look at it from the windscreen in is a hollow void with a sticker in it?
Doesn’t look right to me ?
Morning Ian
The cover inside behind the rearview mirror that covers the sensor just unclips, from your picture it looks like a Dash Cam is fitted I wonder if whoever fitted the camera disturbed the sensor?
My sensor is mounted behind the dark patch at the top of your picture, attached is a picture of mine. There are a couple of small clear areas for the sensor. The sticky pads used are "use once" and the screen needs to be clean and dry. If it was disturbed and then stuck back it possibly has just dropped down and needs a new sticky pad.
Good Luck
Hi Dave, yes there is a dash cam but that’s just a stick on bracket which is under it. I’ll have a poke around behind the mirror. It looks as though the two faults I have are linked to this then by the replies I’ve had?
Many thanks for your help
Ian
      BMW x5 e53 2006 3.0d automatic GB fuel consumption
    3. 5
      Engine noise
    4. 6
      BMW X5 E70 2013 Starting Issues
    5. 6
    • Kokejn earned a badge
    • THFc61 earned a badge
    • Alik989 earned a badge
