BMW X5 E70 4.8 M Sport
Z3 airbag wiring,
This is what was possibly fitted to put the light out originally EMULATOR Link The site link has lots of information about the problem with the seat mat which causes the fault -
5
Z3 airbag wiring,
9
Low Oil Pressure Light on E90
5
Z3 airbag wiring,
Hi David Welcome to the Forum A Vin decoder is a useful tool as it lets you know what was on the original cars build sheet but that only tells you what toys it should have. As its a 2021 car it will have had one MOT which hopefully is clear of any advisories, you can check recall and MOT at www.gov.uk/check-mot-history Next check all tyres are correct and in good condition odd or mismatched tyres can cause havoc with Transfer cases Transmissions and diffs. The rest is History History History plus making sure everything works as it should Good Luck Dave
