i have a 2012 x5 msport 30d e70 and two months ago the fuel return from
the injectors blew off where it joins the T piece next to dipstick sleeve
was under warranty but garage just kept on putting pipie back on
after several recoverys i have it in at my local bmw guru
has anyone came across this issue if so how did you remedy it
thanks derek
Hi Derek Welcome to the Forum
My first though is somewhere the return line is blocked/restricted, I don't have a diesel but even the petrol models have a fuel return with a fuel return valve. Worth checking if yours has a fuel return valve and if it's working? Also check the fuel filler cap is correct for the car
Let us know what they find
Expand
yes i have had the car a year no blockages
biggest problem is that when it blows off it throws up
same faults down to low fuel pressure
next step is to have injectors tested
thanks for the input
If the pipe is blowing off something is causing excess pressure, either a fault in the high pressure pump a blocked or damaged pipe or a connection is damaged. It doesn't make sense to just refit the pipe if it keeps blowing off?? I would at a minimum be changing the return pipe blocked/faulty injectors would have been causing all sorts of other issues.
    2. 4
    3. 17
      2008/09 520d
    • Neil Stokes earned a badge
    • Mish earned a badge
    • Paul M went up a rank
    • Bmw90 jack earned a badge
