E46 330i Radio options !!
Bmw angel eyes
Hi all sorry for the long posy I've got an x3 with adaptive headlights the drivers side Angel eyes don't work but passenger side do I swapped the tms unit over from one side to the other yesterday then neither worked so put back to how it was and passenger side still working does anyone know if the tms module has to be coded for each side and this could be the reason it didn't work when swapped over? Many thanks -
X3 2024 questions
Hey dealership states that the passenger side front seat heater relay sound is typical for this years car. Since the driver side doesn’t do it I am wondering if they just pawning off the issue. I really notice it when breaking. Definitely hear it only when heater is on and only on the passenger side. -
Hi Philip Welcome to the Forum If I recall the Power Steering Fluid was originally a Febi part not sure if it was the Green one to protct seals etc Try taking a look at www.realoem.com Classic section or even ask your Dealer Parts dept they do some good deals on older models Dave
