When you say vibration damper do you mean the main crankshaft pulley on the 4.6 engine it is a 2 piece item bonded together with rubber and sometimes the rubber begins to degrade.
I had to change mine last year once you have stripped all the stuff out of the way it is a straight forward job I also changed both drive belts tensioners and the water pump
Damper/pulley was £125 Waterb pump £40 Belts and Tensioners £120 and the job took a Saturday morning with plenty of tea and biscuit breaks
    5. 2
