hi all, just a silly question can i turn off egr, cat and dpf with computer program without physical taking them off , 525d e60 2004 thank you
snap no idea myself  , quoted 199 to turn off but a bit doubtful , face book guy not garage so i am trying to find out the correct way, as he will take money and disappear
The other thing to consider is MOT I have read that if the car was fitted with DPF as standard and it is missing automatic fail?? One of my sons runs a Toyota Pickup  he has cleaned the EGR once in 5 years and the DPF goes into Regen on its own so personally I don't see the point?
thank you, so not worthwhile to do just leave all alone, was going to delete egr then thought if i do all the junk goes into pdf and cat,  my egr is clean as i done this when i removed swirl flaps ,thanks for advice
      Newbie here
      Appears no fire
      Appears no fire
    5. 12
    • Larry36 earned a badge
    • Graham J earned a badge
    • Sogra earned a badge
    • Aaronelvis earned a badge
