Hi all
ive noticed ive lost all warm air to the drivers side and its still warm on the passenger side, i dont have dual heating,  The drivers side is only blowing cold air, its !Removed! freezing,,   and ive tried all the different vent positions ( window screen and also legs, and face vents ).
cheers guys
Hi Adam
Not sure about the 1 series set up but with the X5 there is a solenoid distribution valve on the nearside inner wing in the engine compartment if it sticks or one of the solenoids fails no heat (why always the driver side?) It could be the air distribution flaps sticking or broken
I would check www.realoem.com and look at the small exploded drawing see if it can give you some clues
      Newbie here
      Appears no fire
      Appears no fire
    4. 12
    • Larry36 earned a badge
    • Graham J earned a badge
    • Sogra earned a badge
    • Aaronelvis earned a badge
