I have a 2008 bmw 123d auto and there is still a little bit of smoke coming from the exhaust but not as much as before I had the inlet manifold cleaned out! Any ideas on what it could be? Thanks
Morning Joel
First you say you had the manifold cleaned ? Was that on the car or off? If on the car was it one of the chemical cleans, Terra clean or similar?
Smoke what colour? white smoke at start up is light residue and condensation this should clear as the engine warms more noticeable on cold mornings. Persistent white smoke at start with a smell of diesel could be a leaking injector or two. Blue smoke is normally oil, valve guides worn turbo seals worn. Black smoke, badly coked engine, over fueling, badly worn engine.
2008 model does it have a DPF? is the EGR in good condition? Or have they been removed/deleted by a previous owner?
      Newbie here
      Appears no fire
      Appears no fire
    4. 12
    • Larry36 earned a badge
    • Graham J earned a badge
    • Sogra earned a badge
    • Aaronelvis earned a badge
