hi my parking sensors are not beeping on my 125i 58 plate,all sensors are clicking. just no beep.
thanks.
Morning Anthony
Simple things unplug each sensor and spray the connector with electrical contact cleaner (not WD40) do the same with the sounder. If that doesn't cure t then you need the codes read to point you in the right place. From your description it could well be the sounder but a read of the fault codes will confirm it.
PS> Take a look at www.newtix.info for more help it is a BMW Technical Information site the same information that dealers use.
ok thanks for that.
i dont suppose you know where the buzzer is located...
not showing any fault codes..
Hi Anthony
2 web site that should help, www.realoem.com a BMW parts website put the last 7 digits of your vin into the search box, it will bring up your model then search the relevant section there will be some small exploded drawings it will also give part numbers and an indicative cost in US dollars. The part numbers are useful to make sure your buying the right part.
www.newtis.info this one is a BMW technical information site, this information is the same as BMW Dealers use for service and repair.
As a clue the sounder on my E53 X5 is under the dash in the drivers footwell.
    4. 9
    • Bubba jay earned a badge
