Hi Rolf
Check www.realoem.com put the last 7 digits of your vin number into the search box it will bring up you model. The site is a BMW online parts list every part available for your model will be listed. If a rear wiper is available then it will be shown with all parts to fit it. You could also try www.newtis.info This one is a BMW Technical Information site Dealerships use this information for service and repair.
Good Luck
PS Just had a look at newtis.info and a rear wiper is shown in the repair list so parts should be available with luck the loom should be there so only the control stalk, wiper and mounting for the motor and local looms will be needed plus a bit of coding to let the car know it's there.
      2008 E61 start issue
    • BmwSpec earned a badge
    • Fretfulmass earned a badge
    • Sambo_gti earned a badge
    • BLM06 earned a badge
