Hi all new to the bm scene.
Nearly there sorting mine out
Just left with a code 2a61 valvetronic adaption.
Tried all the resets wont clear also throws up lamda sensor heating before cat.
Any help would be appreciated 😊
Welcome to the Forum Lee
Sounds like you have done some work ?? Check the sensor and its wiring a BMW specific Diagnostic Program would help.
Lambda sensors are pretty easy to check with a multi meter but if the valve timing is out the lambda doesn't stand a chance.
From memory you have an Actuator (valvetronic), 2 camshaft sensors and a Solenoid valve for the actuator
Good Luck finishing it off
      Tyres for front of my 240i
    5. 0
      520d advice
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
