Accelerator suddenly stops responding but the car has normal idle then it starts to work again it happens every view days
Morning Yanai
Sounds like a failing throttle body, you need a diagnostic session to confirm exactly what the issue.
Hi Stu
If its Petrol it will have a throttle body assembly with integrated position sensor. If its Diesel it will have the AGR assembly and fuel pressure sensor along with all the associated vacuum lines.
Not sure but I think the AGR has a TPS integrated as I am not a diesel driver
What ever he should get a diagnostic check to save some pain to his wallet
      Water leak at sharkfin aerial
    • Driverbus70 earned a badge
    • BLM06 earned a badge
    • Marvin chui earned a badge
    • Davesally earned a badge
    • Backmarker earned a badge
