New E46 owner with a question...
2008/09 520d
16
16
16
Not unusual for the oil level sensor to fail but never heard of one stopping the engine starting, though it does sound logical I changed 3 on the 4.6is but you have to wait until Oil Change as they are in the bottom of the sump Dave
