BMW 650 Electric Conversion
I bought a 2016 X1 2.0D XDrive with 60K now in 2025 for the sole purpose of doing a few EU trips a year. During the second trip, it happened. Errors, etc. I indemnified the errors with BimmerLink and found some forum discussions like this … holy guacamole! Luckily, the car came with a one-year BMW warranty as I bought it straight from them, but still. They’re replacing everything you guys mentioned as well as the turbo. Luckily, it’s all paid for. But the turbo is not in stock, so the car is sitting for seven weeks already at the dealership. Also, I’m planning to keep the car, so will the fault be corrected or can I look forward to having to do this again in four to five years? Any fixes or ideas? -
Can someone please enlighten me on how the auto grill system is supposed to work? My 2018 M40i has this system fitted but I don't recall seeing it closed I understood that it closed during cold weather to allow the engine to warm up quicker. -
		6
Thank you for your interest in this topic. There is some hope that a solution can be found through joint efforts) I eliminated the oil feed pipes.Since the first thing I did was replace the sealing rings there. I am attaching a few more photos showing the leaking area. -
		6
The plot thickens I have changed 2 Turbo's on friends cars but in both cases they were refurbished Turbo's brought as the OEM ones were beyond help. And were fairly straight forward (grazed knuckles) to change. Could the leak you spotted be coming from the Oil Feed pipe ? Dave -
		6
Hi Dave, Sure, realoem. Part number (steel gasket) is 11628576287. and according to the second drawing (please see attached), this is the EGR Line Gasket. Andrew
