Hi guys have A 2004 . 645 having problems with my dash just keeps flickering when the car is hot inside after a hour off driving it works. When the car is cold it does not work. Any help would be great . Have put a video to show you
Hi Paul
Still can't see the Video message says missing Codec not sure if that's on my laptop or your Vid !!
You need to take out the binnacle with the speedo rev counter etc, the connectors are on the back.
Take a look at www.realoem.com either search your car or put the last 7 digits of your Vin into the search box it will bring up your model. Then look at the relevant  section it will have small exploded drawings that should help. Also look at www.pelicanparts.com an American site but apart from the steering wheel being on the wrong side the cars the same they have some brilliant "How To's" with pictures there may be something there that helps.
Fuses are in the glove box awkward to see but worth checking
14 hours ago, Greydog said:
Hi Paul
Cheers dave
    3. 13
    • Mish earned a badge
    • Bmw90 jack earned a badge
