Bonnet release catch e53
This bit! …. Basically, this bolts to the footwell and the lever attaches to the cam. Pulling the lever (cam will go clockwise if it’s on the left) will pull the cable and release the bonnet. if I mount it on the right hand footwell, I would have to push the lever in, not pull it… or there must be a mirror image part for Uk spec? -
Hi Dave… basically when the expansion tank blew last week, I pulled the lever in the footwell a little too well! 😂…. What has broken is the cable end stop on the mounting plate in the footwell… the white plastic thing. I will have to replace the inner and outer cable too, but that’s an easy bit. the websites all show the part with the lever on the right of it, pulling the cable clockwise to open. The Uk version needs to go anticlockwise as it’s on the right hand side. hopefully it makes sense now. -
6
Hi Stu Which bit have you broken 🤪 clumsy boy 🤣 Is it the manual bonnet release with the lever that comes forward through the grill or one of the bowden cable catches? I believe the manual release is the same (left or right) the Bowden Cable releases are the same part or could it be the Bowden cable arm in the footwell ? Dave -
Afternoon all.! silly question, but I have snapped the mounting plate for the bonnet release catch. looking online and realoem shows a part but it’s fitted on the lhd model, which would surely work back to front on the Uk spec RHD model? I can’t find another rhd part code or replacement part. am I missing something, or do both parts fit ?
