I’ve just pulled the small plastic storage compartment out of the boot the one that sits over the passenger side real wheel, once I’d pulled it out I literally say a pool of water!!!! About 2CM deep! I saw a black bung in the space the water is pooling in and (maybe stupidly) decided to pull it out, the water drained out onto the floor from just behind the real wheel! Obviously now I’m in a panic, has anyone else had this? And why is there a plug there!? Help would be much appreciated!!!!
Hi Again
The water shouldn't be there for sure, check there isn't a drain in the area that is blocked but my instinct says you have a leak. Normal suspects are rear light clusters or boot seal possibly sun roof drain blocked and water running from there.
      Mileage
      Mileage
    • Bubba jay earned a badge
