Hi all I have got air to passenger side but not drivers side , but have cold air going both side when cold is selected, not sure if a flap is broke or something along them lines, if so how easy and how do I get to heater box to replace
many thanks for your time in reading my post Adam 😁
Morning Adam
Your issue could be a flap sticking/broken or the FSR (final stage resistor) starting to go. Take a look at www.realoem.com it is an online BMW parts list put the last 7 digits of your Vin into the search box it will call up your model. Then search the relevant sections you will get small exploded drawings which will help identify where stuff fits. Tip if plastic clips are involved buy spares before starting
Good luck
  • 11 months later...
Hi just wondering if anyone knows do all 2012 1 series have a built in screen or is that an added extra ?
Morning J
The answer is it depends what was spec'ed at build
take a look at BMW Vin Decoder put your Vin into the search box and it will call up the build sheet for your car, you should see a list of codes if you can see S606A (Business) or S609A (Professional) it should have a screen
If it was fitted with a basic Business radio set up ?  not sure
Hope that helps
      Newbie here
      Appears no fire
      Appears no fire
    5. 12
    • Drumj earned a badge
    • Larry36 earned a badge
    • Graham J earned a badge
    • Sogra earned a badge
