Hi
I have a 2009 BMW 135i. I got a puncture which was fixed. The thing is though, the puncture warning symbol is still on.
I've checked all tyres and they are all good.
Any clues?
cheers
Nick
Hi Nick
Did the garage/tyre supply place should have reset your system? The system triggers if there is a 25% difference in tyre pressures so first check all pressures make sure they are correct, then there is a reset sequence in your hand book (or You Tube)
17 minutes ago, Greydog said:
Hi Nick
I got a tyres on the drive guy to do it. All tyres have 39PSI in, as done yesterday. I will look on youtube for the reset sequence. thanks
