Can anyone give me sound advice on what is the biggest tyre I can fit to rear 9.5 and front 8.5 . I've been quoted 255 35 19 fro the rest and 225 40 19 for the front but want as much tyre as poss and don't want them looking so low profile and stretched as I have 20" on at the mo running 225 35 20 all round 🤔 Many thanks Steve
Hi Stephen
Take great care as your new wheels are staggered while your current set are square (same size all round) What car did your new wheels come from ? Make sure the Offset is correct front and rear
The staggered 19" Wheels for the X1 should be Front 8J Rear 9J with 225 x 40 tyres Front and 255 x 35 Rear
Tyre sizes are critical to maintain rolling radius front to rear or you can cause serious damage to the transfer case
Hi sorry for late reply , bought them online from alloy specialist I have checked this out and they will fit as looked at other reputable sellers and 8.5front and 9.5 on rear is fine I just really wanted to know if I can get more tyre then 255 35 19 rear and 225 40 19 front . Wheels I have on at mo was an option same all round or staggered so opted for staggered but do see loads of BMW's do have larger wheels on the rear .
Many thanks 👍
Hi Steve
It doesn't matter whether they fit, with just about all AWD/Xdrive cars the rolling radius front to rear must be with a given tolerance to avoid transfer case damage.
As an example my X5 summer wheels are staggered Front 91/2J x 20 Rear 101/2J x 20 Tyres Front  275 x 40 R20 Rear 315 x 35 R20 My winter wheels are 9J x 18 Tyres are 255 x 55 R18 all round
The staggered summer set need the difference in rolling radius front to rear to maintain the rolling radius. The tyre sizes that you have been offered  are as advised by BMW even if the wheel sizes are not. You also need to consider wheel offset so as not to upset geometry in the suspension.
Are you wanting Wider tyres or deeper side wall ? What ever you go for if the rolling radius is out front to rear you could end up with an expensive repair bill for the transfer box or a Diff
  • Thanks 1
Hi Dave, cracking advice mate and you sure know your stuff fella ! It was a deeper wall I was after so am I stuck with what I have been quoted for tyre size front and back ?
Many thanks again and await you reply with thanks Steve 👍
Hi Stephen
So your original tyres are probably Runflat's which combined with their stiff construction and low profile have a reputation for giving a stiff/harsh ride. I helped a friend who has a Merc 4matic transfer case was toast quote from Merc £3k. Before pulling the transfer box (it is better to practice on someone else's car) I put a chalk mark on the front tyre and ground and rear tyre and ground then rolled it forward until the front tyre chalk mark was bottom again the rears had travelled about 80mm further, doesn't sound much but travel a few miles and the strain on the transfer case is enormous. To much for his, we rebuilt it successfully and a new set of tyres he was back on the road costly lesson learned. From other forums dealing with AWD depending on the mechanical set up mis-matched tyres can kill transfer cases and/or diffs.
So some maths your original tyre/wheel combo 225 x 35 x 20 will have a circumference new of 203.1 cm front and rear. The trick now is whatever tyres you choose they need to be within a tiny percentage front to rear circumference to avoid transmission wind up and damage.
So here goes (make sure you check my sums as I am an old bloke)
Say Front wheel tyre combo is 225 x 45 x 19 circumference would be 208.9 cm. So target for the rear has to be as close to that as possible. As an example 255 x 40 x 19 would give a circumference of 209.5 cm, so I think that should work as the sizes are so close a better match would be 235 x 45 x 19 front 212 cm circumference with 265 x 40 x 19 rear 212 cm circumference
That's the maths, in practice if your tyre supplier is helpful maybe put a front and rear side by side and roll them forward to be sure before fitting. If they from the same maker you should be OK ( lucky mine is and I have done this several times)
Bit "War and Peace" but I hope it helps and makes sense
22 hours ago, Greydog said:
Hi Stephen
Hi Dave, again great advice and the the larger depth side wall of the tyre is the look I am after to fill the arches a little more and protect the alloy wheels a little more on pot hole Brisish roads !
21 hours ago, Greydog said:
Hi Stephen
    2. 15
    3. 15
    4. 8
    • Mish earned a badge
    • Paul M went up a rank
    • Bmw90 jack earned a badge
