44cc fault code
I concur with Greydog. I would look at the throttle body and air intake system. unplug the MAF sensor and see how the car runs. Get some carb cleaner in there and see what happens. -
e63 m6 (2010) competition package grill (right) help
Hey, I have a 2010 M6 with the 'competition package' optional extra. The front grills are slightly different in that there is a slight bulge to align with the different bonnet. I've circled this image online to indicate where it is. My issue is that I've gotten a sizable stone chip on the right grill and want to replace it. However, the dealer (and consequently BMW through a request) can't get a part number for it. I'm guessing I'm sod out of luck, but wondering if anyone knows how I could find a part number or otherwise locate the grill. I could of course replace it with an aftermarket, but want the original. Advice appreciated. -
BMW G30 Parking Brake error
Hi, my car suddenly gave an orange error parking brake. When i used the ISTA tool and diagnose it. It gives 2 errors about it. - D35CBA ( electrical parking brake switch fault , DSC-LIN 0x2B) missing - D35CCA (electrical parking brake switch fault , DSC-LIN 0x1) missing When i stop the car and open my door it automatically uses the handbrake and it works fine but other then that, i cant use it.. even the auto hold. If anyone can help me it will be perfect. Thank you -
Morning Paul You have one major answer, your Local Main Dealer is not a good one !! Have you talked to BMW UK Customer services ? Clearly either the Dealer doesn't have a clue or there is an issue they also don't understand ? Worse by telling you a road test would be dangerous are they saying the car is in a dangerous condition ? All questions I would put to BMW UK Good Luck Dave
