I’m having this issue with my 2015 328i xdrive where my radio/nav system boots up, produces like 4-5 seconds of audio over the speakers and then crashes in what sounds like a triple beat thud and then boots up again, repeating the process. Nothing really generates on the screen other than the ConnectedDrive for that same length of time. I was told this is an issue with the CIC and that to replace it would be $3500 or so.
At the risk of this sounding awful, I don’t want to dump $3500 into a radio repair, but I also want to listen to my Music and access the navigation features.
Hi BMW Newb
First a few simple things, have you tried a forced reboot ? Press the CD and DVD Eject Buttons along with the Volume Button hold all 3 down for 5 secs the system should reboot
The next is have the fuses all been checked ? Remove the CIC fuse for at least 15 secs this sometimes kick starts the system again
If those don't work you could google BMW CIC repairers normally repairs are a fraction of the cost of replacement plus as the unit is already registered to your chassis you wont have the hassle of finding some one who can register a replacement to your chassis
Good Luck hope it's the simple stuff
      Water leak at sharkfin aerial
    5. 3
    • BLM06 earned a badge
    • Driverbus70 earned a badge
    • Marvin chui earned a badge
    • Davesally earned a badge
