Some white liner decided to drift and took my d/a mirror with him. I wanted a black set anyway so thought ideal time. But can I find any. eBay seems to have everything but. Or am I looking wrong. 118d e88 63 plate.
Hi Bactongas
Are you looking for a complete mirror assembly ?? Or just the mirror cap ? And are your mirrors fold in or fixed ?
I would check www.realoem.com put the last 7 digits of your Vin into the search box it will bring up your model, then look in the trim section for the part numbers you need as then when you buy you know it will fit. Then search Ebay or other sites for the best price for what you want, as for colour you can take off and paint the mirror caps on your surviving mirror and the drivers door replacement. Or get them painted if you don't fancy trying yourself.
      Water leak at sharkfin aerial
    5. 3
    • BLM06 earned a badge
    • Driverbus70 earned a badge
    • Marvin chui earned a badge
    • Davesally earned a badge
